Volledige vervangingshandleidingen voor de originele iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4, iPhone 4, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS, iPhone XS en iPhone XS Max.
30793 Vragen Bekijk alle
How to use ESD wristbands?
This might be a pretty stupid question, but I'm pretty stumped by this.
I've done quite a few screen repairs but I've been advised to get an ESD wristband. However, I've got no idea how to use them.
I've seen that it's a wristband with a connector attached to it. One end of the wire is the connector that plugs into the wristband and the other is a crocodile pin.
Where on Earth does the crocodile pin go?
I went into a repair shop and then had wristbands that had the same connector on both sides. One connector was on the wristband and the other on a plug in the wall.
So, what should I do?
Thanks.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
The crocodile pin goes to earth :>), earth ground that is. For example if you have a computer case on the bench, the chassis is connected to earth ground via the three-prong plug. If you connect your wrist strap to it, you are now grounded.
https://en.wikipedia.org/wiki/Antistatic...
ESD Wrist Strap, What to Connect To?
Was dit antwoord nuttig?
Score 5
Commentaar:
I’m so sorry, I still don’t really understand. What would the crocodile pin connect to?
door
Theres two parts here the first is the ground reference the ground pin of the electrical outlet works if the outlet is properly wired. The next is having a ESD conductive surface like an ESD mat which is electrically tied to the ground reference. That way the objects (parts & tools) on the mat are discharged safely to ground. The last part is making sure you are also discharged this is where the wrist strap comes in it too needs to be tied to ground or clipped to the mat.
When working on PC's we can cheat as the case can be used as the reference, phones are harder which is why a mat is needed.
door
So, getting an ESD mat is the solution? The pin goes onto the mat and the other onto the wristband? Is that the answer?
door
Well the issue is a matter of what you are working on...
Phones really need a mat, bigger PC's when you're working on replacing RAM or other serviceable parts you just clip your self to the computer frame. When working on logic boards then its best to have a mat.
You can daisy chain the strap to the mat and the the mats connection to the outlets ground point.
The wrist strap has the cable attached or has a snap for a removable cable. The other side of the cable either has a RCA pin connection or alligator clip which could be press fitted over the pin. Some ESD desks have a plug mount for the ESD strap which is why you have removable alligator on some cables.
door
So, if I'm doing basic repairs. Screens, charging ports, etc.. What would you recommend I take into place regarding safety? I'm not in any sort of workshop or anything. Just on my desk.
door
7 commentaren meer tonen
Voeg je antwoord toe
Sam Mileberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 7
Afgelopen 30 Dagen: 32
Altijd: 306
