Kernel Panic with El Capitan and above
MD102LL/A 2.9GHz 8 GB RAM 500GB SSHD 13" Mid 2012
This is a strange one for me. It works just great with Mavericks 10.9.
I have tried it with several drives now and anything El Capitan and over causes a kernel panic. used different drives both internal and external with know good systems. Also downloaded new systems but I soon as I get to El Capitan it fails. Yes I tried High Sierra. This machine was not known for a GPU disorder but that is what I suspect (something in the dual graphics software). Has anyone like @danj seen this?
UPDATE 3/22
I started all over, new drive new cable. Downloaded new clean systems and installed Mountain Lion, Mavericks then Yosemite. Everything worked fine till El Capitan. Then I got the kernel panic screen and a reboot loop. No way to get to Activity our Terminal.
UPDATE 4/3/18
I contacted Apple support on this issue. After a couple of hours and call backs, I have managed to get Apple to better efforts to resolve this. I have uploaded the log to them and it is now going to the specialists for help. They told me they would get back to me within the week. I would not accept the answer of "send it in for a $357 depot repair" as it is a system software issue.
UPDATE 1/14/19
The problem turned out to be Apples’ installation software imposing APFS formatting on 3rd party SSHD drives.
I have found that for it to work on theses drives, you cannot just update, you have go in and reformat the drive APFS, then install a system, then migrate your old data.
Is dit een goede vraag?
3 opmerkingen
@mayer - Can you clear the log file of its history, then capture the event and paste crash report here as a PDF
door Dan
Do you know what the firmware level is? Maybe it didn't get updated.
door Dan
How are you installing these updates are they via the app store or from recovery, regardless of whats installed already instead of COMMAND +R
if u hold OPTION+COMMAND+R it will boot recovery for the latest os compatible with your mac try this instead i had loads of issues with using the app-store. Also at what point dose your mac kernal panic ?
=== Update (03/27/2018) ===
What happens if you try a windows 10 install ?
door lewis Barker
