Ga door naar hoofdinhoud
Proximity sensor doesn't work but camera work.
So, I have recently bought a iPhone 7, and it seems that the screen is not the original one. The problem is that the front camera works great but the proximity sensor not. I have iOS 11 and in the preferences the option to disable or enable the automatic brightness of the screen it's gone... It's possible that the proximity sensors are broken and the device does not present that option because of that ?
Thanks for helping! I have attached a print screen from the iPhone.
Regards
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The proximity sensor has nothing to do with the auto-brightness feature. It is used to disable the screen when you make a call; it will detect that the phone is pressed against your cheek and close the display so that the digitizer doesn't register any touching.
During the previous repair, it is possible that the prox sensor was incorrectly positioned or possibly even damaged. It is part of the FCAM flex. You can check that yourself via this guide.
As for the auto-brightness, that function was moved to the Settings/General/Accessibility/Display Accomodations menu.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Ok ok , proximity sensor definitely don't work, because in calls the screen remain on! But the weird thing is that in Settings/General/Accessibility/Display Accomodations menu the automatic brightness option does not appear ... My print is in Portuguese sorry about that but is in that menu. It is possible that the flex are broken? And iPhone doesn't recognize the sensor so the option in menu is unavailable ? Regards
door
Voeg je antwoord toe
julioficabem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,924
