Ga door naar hoofdinhoud
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
6 Vragen Bekijk alle
Bit won't come out of the chuck.
I used my drill today and I went to drill a into a piece of brick and the bit went back into the drill somehow. I can open and close the chuck but the drill bit will not come out. When I push on the end of the chuck it goes into the drill, it has a lot of movement.
I tried everything to try and get the drill bit out, nothing works, I don't understand how it could get stuck in the drill when I can still open and close the teeth to the chuck. Thanks.
Joel
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Open the chuck as wide as it will go. Hold it with the opening pointing down and tap the chuck with a small hammer till you can either grasp the bit with a pair of needle nose pliers or it falls out.
Was dit antwoord nuttig?
Score 4
The bit you were using got jammed into screw that holds your chuck in place.
If you can still grsp the end of the drill bit with a bair of plyers bring the jaws of the chuck to the edge. Place a washer over the bit. Clamp a pair of vise grips on the bit and then turn the chuck out. The washer is just to protect the jaws. you might need to turn the chuck with a pair of channel locks.
Voeg je antwoord toe
Joel Silva zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 7,787
