Ga door naar hoofdinhoud
This Power Mac G4 has Mirrored Drive Doors.
80 Vragen Bekijk alle
Why won't it power up?
My G4 won't power up. I press the power button it turns on the off immediately. The fan tries to start but stops immediately. After I press the power button once, it won't light up again. I have to unplug the CPU and then plug it back in. Then when I try it again, same thing. I already replaced the little battery inside. Didn't help. This has been going on for a while. If I keep trying, sometimes it starts. I have the 867Mhz machine. What part is bad? Can I replace the faulty part myself? If so, is there step-by-step directions for this anywhere?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Its probably the power supply. A well know problem with the Powermacs. I'm listing an URL for a video on replacing the power supply in an MDD. The procedure is basically the same in most powermacs but ifixit has teardowns for other powermac models. Just check the teardowns page for your model if its not the MDD. Ralph
http://www.youtube.com/watch?v=uEfNH1DaJ...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you. The video is helpful. Doesn't seem so bad to replace. Now if I could only find a power supply that doesn't cost more than the computer is worth. The MDDs are selling on e-bay for $175 or less.....
door
I don't know if you want to go there but heres a link to convert a regular PC power supply to work in a MDD. Ralph
http://www.applefritter.com/node/23857
door
Have you tried resetting the "PMU" button on the logic board? This worked for me a while ago. http://docs.info.apple.com/article.html?...
Voeg je antwoord toe
Jim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 4,080
