Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
601 Vragen Bekijk alle
Is it safe to give corroded Xbox One board an alcohol bath?
Can I soak a Xbox One motherboard with corrosion in 90% rubbing alcohol? It has tough corrosion I can't get off with a wipe. Just wanted to make sure this was safe, thanks in advance!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
De essentiële toolkit
De meest behulpzame tools in onze meest compacte kit.
Koop nu
Koop nu
2 Antwoorden
Gekozen oplossing
Hello Reed,
Yes it is totally safe to soak the board in alcohol so long as it is not energized. Be sure to air dry it or use a blow dryer on it to evaporate the alcohol before plugging it back in. Alcohol will not however do much to the corrosion itself but you probably should use a brush to loosen any corrosion while it is submerged. Do NOT use water at all, at anytime or the unit will not dry out very good and the corrosion will grow!
You could also use a pencil eraser to remove the corrosion.
Good luck, I hope this helps.
Rich Lilja
Was dit antwoord nuttig?
Score 1
Commentaar:
I thought so! I appreciate the confirmation.
door
Do you mean sticking the entire motherboard in isopropyl alcohol to soak? and for how long?
Voeg je antwoord toe
Reed Crosby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 640
