Ga door naar hoofdinhoud
Model A1320 / 8 or 16 GB capacity
154 Vragen Bekijk alle
Did I just ruin this iPod?
I was trying to remove the battery from the logicboard, and two little brown pads came off of the board , did I just ruin this ipod?? It's my sons and he's going to be heartbroken. I can't afford to get another one please help me fix this someone.
Update (03/12/2018)
Attached are pictures of the solder connections on both the battery ribbon and board
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
if the two little brown pads that came off are fabric-like then you should be fine, if it is anything else i'm not sure
Was dit antwoord nuttig?
2 opmerkingen:
The pads were the point on the board that the battery ribbon was soldered to
door
Can you add a picture? if its the pads that came off, you may (with a little bit of soldering experience), be able to run a jumper to the pulled pad from the trace its connected to.
door
if theres any solder left on the board you can use carefully rebuild the connection...if not youll need to find an alternate solution to charge...you can get a new logic board and battery for under $20 online .
Voeg je antwoord toe
plantdad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 114
