Ga door naar hoofdinhoud
Which wire goes where on the Imac Mic?
I accidentally pulled the wire off of the iMac mic and wondered which wire went where? Here is where I saw a picture but couldn't tell where each wire went.
iMac G5 20" Model A1145 Microphone Replacement
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Magnifying the picture the black wire is on the left and the white wire is on the right/positive terminal. Ralph
Was dit antwoord nuttig?
Score 3
Thanks That helped and it worked. My wires were black and gray. I still used the black wire as negative and it worked. Thank you very much you save me a lot of money!
Jonathan
Voeg je antwoord toe
Jonathan Hirtle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,431
