7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
217 Vragen Bekijk alle
My ipad won't turn back on after charging to 100%.
My iPad works fine until I charge it to 100%. When it gets to 100% it will take days for it to turn back on. I've tried different sockets, plugs and I've tried hard resetting it. Sometimes it will turn back on after a few days but now it's not coming back on.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
I'm curious...when it eventually does turn back on, is the battery still at 100% or has it lost some charge?
I have not seen this problem and other than the battery or a logic board issue, I can't imagine what could cause this. Next time the iPad is functional, try testing the battery health with a tool like coconutBattery (Mac) or 3uTools (Windows). If it is anywhere below 60%, you should change your battery.
If a new battery doesn't help, then it is probably an issue with the logic board.
Was dit antwoord nuttig?
Score 3
Commentaar:
When it turns on it is back at 100% but I have to leave it on or use it for a bit so that it loses a little bit of charge otherwise it will just die again.
door
Voeg je antwoord toe
Deanna Mathieson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 14
Altijd: 378
