Ga door naar hoofdinhoud
The Pronto Digital Kitchen Scale is a multifunction device, manufactured by Ozeri, for easy use when measuring various items up to 11 pounds (5050 grams) with 1 ounce (0.05 grams) graduations .
6 Vragen Bekijk alle
Why does my scale show out2 or 0_Ld?
Why is my scale reading out2 and 0_Ld after I turn it on and why cant I recalibrate it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi ,
Is the weigh plate sitting correctly?
If it is then it seems as though a weight sensor may be faulty and is registering a reading when it shouldn't (O-Ld = Overloaded perhaps), or its' control board has developed a fault.
Here is a link to the ifixit Ozeri Pronto ZK14-S Wire Replacement guide which may be of some help.
Was dit antwoord nuttig?
Het nuttigste antwoord
I managed to fix the Out2 error problem and I don’t think it has anything to do with overloading or calibration. Take out the battery. Then, take the 2 halves of the scale apart by undoing the 2 screws underneath the CE label on the back. Then you need to carefully clean around the 2 buttons - I used a very fine steel pick. A thick needle would probably work as well, just gently scrape around the buttons from both the outside face and as far underneath you can get on the inside face of each button. But the magic solution was a very slight spray of CRC where the buttons make contact. I probably sprayed a bit too much, but it worked immediately. Screw the 2 halves back together, insert the battery, job done. My Salter is around 8 years old and hopefully will go another 8. Good luck!
Score 1
Voeg je antwoord toe
Donald Bollman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 158
Afgelopen 30 dagen: 610
Altijd: 31,134
