Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Reparatiehandleidingen en ondersteuning voor auto's geproduceerd door het Duitse bedrijf Audi.
51 Vragen Bekijk alle
Where is the thermostat located in a 1992 Audi 100s?
I'm having trouble locating the thermastat so I can replace it
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The thermostat will be where the radiator hose attaches to the engine block. You can't see it without the radiator hose off. A quick internet search tells me that your Audi's thermostat might be near the lower radiator hose, but I've seen them on other cars on the upper hose.
Drain your radiator and take off the lower hose. Keep that bucket ready, because the engine block will drain when you take the hose and 'stat off. Once you remove the hose you should see the thermostat in the center of the tube you removed the hose from. It's that brass thing in there. The metal tube that the hose mounts to should have a couple of bolts holding it on. Remove the bolts, give the piece a smack to knock it loose, and pull out the thermostat. Make sure you clean everything up and put a new gasket on before you close it up again.
Was dit antwoord nuttig?
Score 3
Commentaar:
+ another nice contribution
door
+ sounds good and fun to do. Do not let the antifreeze spill on your drive way or etc. It is poisonous to animals and children. Discard unused antifreeze properly.
door
Voeg je antwoord toe
Ron Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 635
