MacBook "Charged" at 100% shuts down without power.Temperature -273,2C
Hello there! I was browsing the web from my macbook (when magsefe was unpluged) and suddenly it has shut down!
After I plugged the power adapter into it, MacBook shows 100% battery, Magsafe indicator is green.
Without power MacBook shuts down instantly.
The coconutBattery shows different information every 10 seconds.
The first case:
'''Manufacture date: 1979-11-30
Cycle Count: 32768
Full charge capacity: 32768 mAh (100%)
Design Capacity: 0 mAh (100%)
Battery status: Good
Battery temperature -273.2 C
Charging with: 0 Watts'''
The second case is similar to the first one but all fields are NaN and temperature stays at -273.2 C.
Macbook is not water demaged.
I have tried SMC reset but it didn't worked for me.
If battery disconnected, MacBook becomes slow and laggy.
Does it looks like the battery problem or is it problem with my MacBook?
Please help!
Thank you.
UPD: battery replacement solved the problem!
Thanks everyone for answers!
Is dit een goede vraag?
2 opmerkingen
Do you have another battery to test with?
door S W
Nope. That's a problem.
I can't order a $30 battery just to test.
So I need to know does it looks like an SMC chip problem or something, or just a battery problem.
Thanks for response.
door Braves Only
