Ga door naar hoofdinhoud
Reparatiehandleidingen voor een scala aan old school spelconsoles.
102 Vragen Bekijk alle
Atari Flashback no image displaying
Hello, my atari flashback 8 is not showing any display. It shows a bunch of white and black lines and that's it. At first we thought it was a our TV being too modern it can't pickup the refresh rate of the atari system but, we then got an old CRT TV and it is still not working. Next im thinking of taking it apart and seeing if something on the inside is busted. Please help!
Update (02/25/2018)
Here is an image of the console for u to see
Is dit een goede vraag?
11 opmerkingen
Micheal Cini are you sure it is a Flashback 8? The Flashback 8 has HDMI video output etc. so your TV should not be to new for it. Is it possible that you have a original Atari2600?
door
Im 100% sure its not the original atari2600. It has no catridge slot and only buttons I shall add an image of it for you to see
door
In that case you do not need an old TV. This one has HDMI output. Has it ever worked for you? did you buy it new? Any known history on this?
door
It only has A/V output. No HDMI, the Flashback 8 Gold has an HDMI output, but, not the one I have. It is brand new and has not worked since I bought it.
door
same problem and although the box shows it is supposed to have hdmi output it does not.....only av
door
6 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Micheal Cini Use a TV with Component inputs. Most modern Tv have this and if you let us know what TV you have we can probably help you with that as well. Use the guide to setup your Atari. If everything is properly connected and the TV is properly setup as well, you should get a pictures. Let us know when you have done so. Atari-Flashback-8-Instruction-.pdf
Was dit antwoord nuttig?
Score 3
16 opmerkingen:
I have tried that already following what the guide says. Nothing happens, I have no clue... I tried everything!
door
What make and model is your TV?
door
It is a Panasonic TC-60PS34
door
I have a VIZIO TV & just purchased my Atari flashback 8 & I too have tried everything, from switching the inputs to moving the cable cords for the Atari around in back of the TV. But still there is still no luck. I don't know what to do at this point, I loss for words & getting frustrated too. Can you please help me with getting it up & running.
door
Hi @sexydeva6950,
Can you try connecting it to another TV to prove where the problem is, either with the TV or the console?
What is the model number of the TV?
door
11 commentaren meer tonen
Voeg je antwoord toe
Micheal Cini zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 7,595
