Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
My samsung won't connect to *118# malaysia recharge/check bala numbers
My partner Mick and I both have Samsung S5 movile phones. We are Australians living in Malaysia. We use Umobile. His phone can call the recharge *118# numbers but my phone won't connect to these numbers. Why? No one can tell me.
The only difference is mine is the Korean version.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @brendafrancis ,
Are you getting an "invalid MML code" message?
If so you have already found out the answer.
It is a South Korean phone.
Researching online shows that for these phones to work outside of South Korea they have to be initially activated in South Korea, but even though this means that they are then unlocked and should work worldwide, it doesn't mean that they will be able to have all the same attributes as an identical phone made for a different part of the world or even the 'international" model.
To get certain facilities to work, others have rooted the South Korean phone and installed custom roms.
Here is a link, not really relevant to your particular problem, but it shows that others are having problems getting South Korean phones / tablets to fully function in other parts of the world.
You may have to find another way to recharge and check your balance.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Brenda Francis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 207
