Ga door naar hoofdinhoud
The fourth-generation Surface Pro tablet, released October 26th, 2015.
What is the suggested temperature of a heat gun to remove the screen?
Hi, I'm gonna try to open my Surface Pro to upgrade the SSD from 256 to 1T.
What is the temperature I have to set the heat gun to work on the screen removal?
Is dit een goede vraag?
Score 7
1 Opmerking
Hey there. Would love to know how the OP went with this. I'm also thinking of upgrading my surface book 2 256gb to 1TB!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@tpcware usual temperatures for this is between 80 and 100 degrees Celsius with 80 degree Celsius being standard. To hot and your LCD will get damaged.
Was dit antwoord nuttig?
Score 9
6 opmerkingen:
Thanks for your kind reply. Should I assume you're talking about Celsius degree or Fahrenheit degree?
Because 80°F really differ from 80°C (that is 176°F)...
door
80°C-100°C.
Make sure not to push up against the glass or it will most likely crack the screen. What I do is cut through the adhesive, maybe some very thin flexible cards will cut the adhesive well.
door
@tpcware that's a big Duh on my part. Sorry, those temps are in Celsius.
door
yeah if you have access to a heat pad I'd highly recommend putting the tablet face down on a heat pad that has been set 80 C as opposed to use a heat gun as if you only have two hands then one will be required to hold the heat gun while you're trying to separate the display.
door
How hot is "too hot" ?
door
1 commentaar meer tonen
Voeg je antwoord toe
n.carandini zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 59
Afgelopen 30 dagen: 203
Altijd: 40,837
