Ga door naar hoofdinhoud
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Washer doesn't fill with water on rinse cycle.
Kenmore washer does not fill with water for rinse cycle
Is dit een goede vraag?
Score 4
1 Opmerking
What colors should I expect on Inglis Washing Machine ITW4300XQ0
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If the washer drains after washing but will not fill in the rinse cycle then checking the pressure switch would be a good idea. If the tub is empty you can remove the plastic hose, give the switch a thump and reattach the hose. Does it fill now?
If not then you can remove the violet wire and tan wire from the pressure switch and join them together with a small piece of insulated wire.
Remember to unplug the washer first before attempting this.
With these two wires connected the washer will fill if the pressure switch is the problem.
Was dit antwoord nuttig?
Score 7
5 opmerkingen:
Did that and it worked!!!!
door
my wires are purple orange and pink ???
door
Remove which plastic hose?
door
@Rey “Manzo” Manzanares
There is a plastic hose that goes from the bottom of the tub up to the water pressure switch in the control panel.
As the water rises in the tub it also rises in the hose and this increases the air pressure on the switch, which has contacts that close as the switch operates with the ever increasing pressure and then it shuts off the water at the required level.
door
This, if the washer fills to wash, but rinse is less than small load? Inglis ITW4300XQ0?
door
Found it to be the drainage hose was too far in the
drain pipe. Pulled out the drainage hose . I immediately heard a lot of gurgling and water started to drain
ran a cycle, and it worked like it should
so, pulling the hose out of the drain, and re-seating it,
resolved the issue
Score 1
Voeg je antwoord toe
Cindy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 46
Altijd: 29,758
