Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2688 Vragen Bekijk alle
iPhone 6s Won’t Charge Or Connect To iTunes
Hi, device is an iPhone 6s, came in with no power and wasn’t drawing any power from charger.
First thoughts were charging port as Lightning Cable felt a wee bit loose when connected
I placed a new battery on top of the old one just to attempt to power on device and it booted on just fine.
I tried charging once powered on but still nothing. Therefore I went ahead and changed the charging port but still the device won’t charge or be picked up by computer.
Am I right in ruling out charge ic as Would a charge ic issue still let you connect to computer?
Have tried 2 ports in case one had a Fault.
No sign of any charging port connector damage under scope.
Any tips appreciated thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Tristar chip needs replaced, microsoldering job.
Symptoms of bad tristar:
- iPhone not being detected by computer
- Not charging while on
- Not charging when battery is flat
- Apple logo not displaying when battery is unplugged and charger is plugged in.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Niall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 770
