How do I fix dark screen but can faintly see picture when I hold light
I have LG 47LN5200-UB, has been working fine but two nights ago went to turn it on and screen is black. I can see a Faint picture if I hold a flash light up to the screen.
I have tried unplugging it, holding the power button for 10 seconds and plugging it back in. I tried switching picture settings to vivid. But did not help. Sound works fine.
What else can I try.
Is dit een goede vraag?
7 opmerkingen
Also when I power on the TV, a light flashes across the screen then goes black. With just a really faint tint of picture or menu on the screen. Can only be seen when you're holding a flash light up to the screen. Sound works perfectly to what ever input you select.
door Sandy
I can’t see picture what do I do to fix it
door Justin b hopkins
Mine started backlight problems, I don't know if this is only happens to LG digital set. Please how can I fix.
door John
I don't know if this is the reason but I suffer from the same problem but I believe that the TV isn't getting enough power from the cable you plug into the outlet
I Feel That's The Problem
door Amani
Hi there if got a aim TV also if I hold my torch can see the picture settings I've done scan reset it all of that it work yesterday but when I turn it on today got little picture of i put my flash light
door Shaun Buys
2 commentaren meer tonen
