Ga door naar hoofdinhoud
Repair guides and support for a wide range of mattresses.
6 Vragen Bekijk alle
How can I get my mattress repaired?
Can anyone fix a ripped mattress I want it done professionally? I can not seem to find anyone at this time
Is dit een goede vraag?
Score 1
1 Opmerking
I need someone to fix a zipper on my mattress
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Here's a video on how to do it: https://www.hunker.com/13403914/mattress...
If you don't want to do it yourself, call fabric store and ask if they have a contact.
Was dit antwoord nuttig?
Score 1
A mattress is simply covered in a lot of fabric with a lot of sewing.
Consider researching mobile seamstresses or tailors to see if they are willing to repair the mattress.
Google and Yelp! are your best resources for this.
Score 1
2 opmerkingen:
Is there anyone who can clean a new mattress that has had about a cup of oil spilt on one corner of a new king size mattress?
door
Just use a standard carpet cleaner. Mattresses are large enough that you can run a carpet cleaner over a mattress like you use it on the floor.
door
Frankly speaking, I have never heard about the services for the repair of mattresses. Honestly, I think that a simple tailor won't take up such a job. If the damage that you have is not so serious and you can hide it with the help of a dense mattress pad. We have a dog and she always bites all the furniture in our house. She also toured our mattress with her teeth. To cut II short, we just ordered a qualitative mattress pad from mymattresspads.com and such a way the lying on it is also convenient and the hole does not interfere with good sleep.
Yes, you can fix the ripped mattress. Spray inside the tear with adhesive, covering both sides of the tear within the foam; be sure some of the adhesive reaches near the edges to create a lasting bond. Allow adhesive to dry for 10 to 15 seconds, then press the foam sides together, closing the tear. Hold in place for 20 or 30 seconds.
Voeg je antwoord toe
Vivian Roberts zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 75
Afgelopen 30 dagen: 283
Altijd: 5,907
