Ga door naar hoofdinhoud
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
Broken screen can't deactivate
I recently cracked the edge of my screen causing a few problems so I turned off screen lock and seems ok 90% of the time. Today's problem is I put battery saver on as was out and only had 5% and now I can't disable it as the screen times out straight away. To be able to get the phone screen back to working order I need to disable the saver back to normal. Help
Is dit een goede vraag?
Score 4
2 opmerkingen
It fixed my problem as weel. I was unable to turn off the device and boot into recovery mode. Thanks for the post
door
Hi my s7 edge has a broken screen cant see anything, and i accidentally turned on battery optimization pl3ase helo!?!?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Try this:-
You can force Galaxy S7 or S7 edge to power off without unlocking the phone by following these steps:
Step 1: Connect Galaxy S7 and S7 edge to wall charger with the USB cable and make sure it is charging.
Step 2: Press and hold Volume down button and Power button (holding two buttons) for about 7 seconds.
Step 3: Release power button, then volume down button.
Now, Galaxy S7 or S7 edge should be powered off. You can wake up the screen to verify. It should show a charging battery icon.
Was dit antwoord nuttig?
Score 22
11 opmerkingen:
I have spent hours trying to find a solution. This is the only one that works. Thank you very, very much. Now I can boot into TWRP and get all my files out.
door
yes this is hard to find knowledge! On my broken note 5, this solution works too (just pressing down + power button only reboots phone, not power off). Samsung should have made it easier to force power off phone with sealed in battery
door
100% working for my broken screen,Thanks
door
This doesn't work for me. It's just causing the hard reset but the phone immediately powers back up. I need the phone to stay off so I can take out my sim card
door
when i try this it just restarts my phone? HELP PLEASE.
door
6 commentaren meer tonen
My Galaxy 7 started repeatedly rebooting and the hard shut off did not work. I have a replacement phone but have files I need to get off the G7. Is there another way to cancel the automatic rebooting process that the phone is stuck in?
Score 1
It's really too bad that no one has a universal fix for this. What i ended up doing was taking the phone apart and removing the battery. What could be the problem is the button mechanisms are faulty from the damage as well.
Thank you very much ... It did work
Voeg je antwoord toe
Kel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 67,110
