glass not flush after screen replacement
Hi,
I have taken apart this iphone 3 times already, every time i put it together the screen is slightly raised
this causes problems,the glass is not flush and neither is the home button. If I press the glass down to make it flush, you can see bruises on the lcd.
I bought this replacement off of ebay. Could it be a faulty screen?
I followed directions to THE KEY. I do this stuff for a living so I dont see anything wrong
I have everything taken apart in front of me trying to see what causing the misaligment but I am completely stumped
It feels like it is too thick or something, like its not the correct fit
Is dit een goede vraag?
1 Opmerking
I'm having a very similar issue. I replaced my iPhone 4's LCD/front panel earlier this evening, because the original one cracked.
After installing the new display and re-assembling the phone, I noticed that the home-button felt a bit more sunken in, than before (my guess, by as much as a millimeter).
So I took the phone apart once again, to check whether I had not fully pressed the new display into place, before tightening the screws. But everything looked like it was as far in as it could go. So I again re-assembled the device, to no avail. It almost feels like the glass itself is thicker or something...
Is there a way to fix this, or perhaps place something under the home button to slightly raise it? My concern is that over time, the moisture from fingers and general use, would seep in through a gap (if there is any), when the button is pressed down.
door N Sosa
