Ga door naar hoofdinhoud
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Black screen with power
Hi,
The monitor was working perfectly last night. Today, the screen won't light up even a little bit.
The cables are ok, power and USB are delivering.
Is it just dead, or is there any way to find a replacement part? If so, what part am I looking for?
Is dit een goede vraag?
1 Opmerking
Hello Alan, Ben,
Do you have any solution on this? I got the same issue on mine.
Thanks,
Alex
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You'll need to do the flashlight test!
Take a flashlight and place it on the screen at about a 20 degree angle with the monitor turned on and plugged in. Do you see a faint image of your desktop & icons? If you do then we know the displays backlight is in trouble.
Let us know what you find!
Was dit antwoord nuttig?
Score 1
Hi Alan,
Any news on this? A recently acquired 24” Cinema Display is doing the same, no faint image either.
USB, Sound iSight all recognised but not the display. Tried on both iMac and MacBook pro - both work with another monitor on the same ports.
Thanks,
Ben
1 Opmerking:
In your case I would check the power supply lines going to the logic board within the display. If they are at the correct voltages then the logic board has a problem.
door
Looks like this questions was answered here more thoroughly: Black Screen with Sound
Voeg je antwoord toe
Alan Eyzaguirre zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,257
