Ga door naar hoofdinhoud
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
83 Vragen Bekijk alle
Black screen with power
Hi,
The monitor was working perfectly last night. Today, the screen won't light up even a little bit.
The cables are ok, power and USB are delivering.
Is it just dead, or is there any way to find a replacement part? If so, what part am I looking for?
Is dit een goede vraag?
1 Opmerking
Hello Alan, Ben,
Do you have any solution on this? I got the same issue on mine.
Thanks,
Alex
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You'll need to do the flashlight test!
Take a flashlight and place it on the screen at about a 20 degree angle with the monitor turned on and plugged in. Do you see a faint image of your desktop & icons? If you do then we know the displays backlight is in trouble.
Let us know what you find!
Was dit antwoord nuttig?
Score 1
Hi Alan,
Any news on this? A recently acquired 24” Cinema Display is doing the same, no faint image either.
USB, Sound iSight all recognised but not the display. Tried on both iMac and MacBook pro - both work with another monitor on the same ports.
Thanks,
Ben
1 Opmerking:
In your case I would check the power supply lines going to the logic board within the display. If they are at the correct voltages then the logic board has a problem.
door
Looks like this questions was answered here more thoroughly: Black Screen with Sound
Voeg je antwoord toe
Alan Eyzaguirre zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 3,094
