Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
896 Vragen Bekijk alle
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
Is dit een goede vraag?
Score 14
4 opmerkingen
It worked, oldturkey. Thank you for protecting me from my own karma.
door
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
door
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
door
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
Was dit antwoord nuttig?
Score 20
32 opmerkingen:
Had same problem. Solution worked. Thank you very much.
door
awesome...problem solved...thanks
door
Nice. Thank you. Problem solved!
door
Thanks so much! worked perfectly
door
@Matt Tierney, you are welcome :)
door
27 commentaren meer tonen
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
1 Opmerking:
Yea as this is where the "Tunes" are kept.
door
Voeg je antwoord toe
Danielle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 64
Altijd: 48,364
