Ga door naar hoofdinhoud
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
144 Vragen Bekijk alle
Why doesn't my Samsung device recognize the micro SD card I install?
On my Samsung Galaxy Grand Prime, Model#: SM-S920L, why won't it recognize when I install a micro sd card for expanded memory? I've tried an HC 8Gig card as well as a Samsung brand 32Gig card but it won't read that there is a card in there at all. Is the reader damaged? The prongs of the reader have to meet the pads on the sd card, right? So maybe the prongs are bent? How can I fix this issue PLEASE!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The phone appears to be dual sim, with the main sim reader having a microSD reader at the top.
My guess is the microSD card reader pins have been damaged or bent.
Unfortunately if this is really the case a new one would need to be resoldered on.
Not much people would do this as a rework station is needed, if you can find someone that does micro-soldering they can do this for you.
I think you should be able to visually inspect for damage easily with the use of a microscope and looking into the slot with a light source.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you, Ben. I appreciate that. Is there no way of simply bending them back into place if they've just been bent?
door
Yeah you can with tweezers but you would have to be very careful, bending them back too much may cause one or more of the pins to break off.
door
Het nuttigste antwoord
Hi,
Just double checking that you have inserted the card(s) until they 'click' into place and that to remove the card(s) you have to push it in further so that it springs back out.
Also have you tried mounting the SD Card?
Go to Apps > Settings > Storage > tap Mount SD card.
Score 2
3 opmerkingen:
Thanks Jayeff, for your response. I have inserted the cards fully each time and the option to Mount SD Card is grey'ed out in the settings. That's my problem. The phone doesn't recognize that one is present when it clearly is.
door
Hi,
Has it worked before OK?
My only thought is to try a factory reset just in case it is a software glitch that is causing the problem and not as you are probably correct in saying that it is a hardware fault. Initially it is less intrusive than having to open the phone and possibly causing more problems
If you do decide to try this remember to "back up" the phone first. That way when you wish to restore the phone after the reset has either proved or disproved whether it is hardware related or not you can go back to where you were before you started.
door
Format the card
door
Voeg je antwoord toe
Grayson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 13,641
