Ga door naar hoofdinhoud
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1190 Vragen Bekijk alle
Hard disc drive replacement not SSD.
Hello everybody,
My Aspire One 110 laptop's SSD has crashed and I'm looking for a valid replacement.
All topics I've found browsing are a couple of years old and I'm not sure about witch or where buy a new one, that I can use with this tutorial .
Thanks.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It looks like it uses a standard 9mm 2.5" laptop drive such as this: 750 GB 7200 RPM Seagate SATA Hard Drive (New)[gekoppeld product ontbreekt of is uitgeschakeld: IF107-099]
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
looks like the 110 does use a standard hard drive: http://www.sparepartswarehouse.com/Acer,...
door
Hi again Mayer,
I have a 110 model.
Does it changes the guide steps a lot of?
Thanks.
door
Thanks for your answer, mayer,
just one little question. Does the hd has a zip connector? I've read in many places that I need this connexion for my laptop.
I liked this HS 320GB because is not my main computer.
Thanks for you time and best regards.
door
You have actually given two machines, your link is to a D150 the guide is to a 110. I gave an answer for the D150. What do you have?
door
Voeg je antwoord toe
pdeandres35 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,080
