Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Screw identification help iPhone 4
Does anybody have a layout of what screws go into which hole?
There are several obvious locations for the washers and broad head screws but a majority of them are a mystery if you don't keep track of them.
I had an orderly system set up but I tipped my tray and it's all jumbled. On top of that I lost a handful of tiny screws so I ordered a replacement kit.
I want to make sure i'm doing it right this time and based on just numeric descriptions "2.5mm" i'm unable to determine which screw is what.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Here is a chart I created for Verizon iPhone 4S.. Does not include the 6 screws and washers holding the LCD to the mid frame, since you do not need to remove them ..
Size Type Location
3.6 mm - Pentalobe - Dock Connector
1.5 mm - Phillips - Battery Connector
1.8 mm - Phillips - Dock Connector - Logic Board
1.6 mm - Phillips - Logic Board near vibrator
1.3 mm - Phillips - Rear Camera - Red
1.5 mm - Phillips - Rear Camera - Orange
2.4 mm - Phillips - Rear Camera - Yellow
4.8 mm - Flat - Top near headphone jack
2.5 mm - Phillips - Top near power button
3.4 mm - Phillips - Near vibrator motor - Red
3.6 mm - Flat - Near battery - Orange
2.4 mm - Phillips - Speaker enclosure
1.6 mm - Phillips - 1 of 4 corner
1.6 mm - Phillips - 2 of 4 corner
1.6 mm - Phillips - 3 of 4 corner
1.6 mm - Phillips - 4 of 4 corner
Details:
Size Amounts Type
1.3 mm - 3 - Phillips
1.5 mm - 2 - Phillips
1.6 mm - 5 - Phillips
1.8 mm - 2 - Phillips
2.4 mm - 3 - Phillips
2.5 mm - 1 - Phillips
3.4 mm - 1 - Phillips
3.6 mm - 2 - Pentalobe
3.6 mm - 1 - Flat
4.8 mm - 1 - Flat
Total 21
17 Phillips
2 Pentalobe
2 flat
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Where do I find IFIX shop around Johannesburg in South Africa to purchase this screw drivers?
door
This is also helpful http://www.powerbookmedic.com/wordpress/...
Score 1
The title of this is "iPhone 4" but the list of screws is for "Verizon 4S" and some screw sizes will differ. The screws in the iPhone 4 can be the same length but some differ in diameter. A calliper is instrumental in defining the sizes.
Also, I'd like to suggest using rubbing alcohol and a screen cleaning cloth for cleaning connections. It doesn't leave a film and evaporates quickly, so no need to "dry" after use. Just don't use excessive amounts.
Cheers and good luck!!!
Score 1
All I can say is to maybe look back at the teardown and compare size & shape.
I recommend using this next time:
http://unitediphonerepair.com/?option=co...
Voeg je antwoord toe
charles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 32,336
