Can I upgrade the flash memory in my iPhone 4s
From somebody else's flash memory from an iCloud locked iPhone 4 S?
Is dit een goede vraag?
Yes you can however it is a very time consuming and complex process that will not make economical sense. First the existing NAND IC has to be desoldered and "read" via a specialized NAND programmer to get all the metadata (SN# etc). Then the other NAND IC will have to be desoldered from the donor board. It will then be programmed with the previous metadata and then re-soldered onto the logic board. As with any micro-solder repair, there is always a certain level of risk involved. This is not a DIY repair and you will need to find a micro-solderer to do this.
I can't see anyone charging less than the actual value of an iPhone 4S so it's probably not really worth it.
Was dit antwoord nuttig?
Agreed! Not worth doing when you can buy a new phone for less than buying all of the equipment and parts to alter your's and you know it will work! Altering your phone may kill it!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 475
