Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1887 Vragen Bekijk alle
How do I downgrade back to IOS 10 from IOS 11.2.1
how do i install an unsigned firmware (IOS 10) to my iphone 6S running on IOS 11.2.1
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 2
Commentaar:
Since you are already so far in IOS 11, the only way to downgrade would be to jailbreak. Which potentially, could risk you to mess up your software to the point where your phone is unusable.
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
4 Antwoorden
Gekozen oplossing
Unfortunately, it is no longer possible to downgrade your iOS to version 10.X as Apple is only signing the 11.2.X version at this time unless you had previously saved your SHSH2 Blob (see this article on GadgetHacks).
Was dit antwoord nuttig?
Score 2
You can't. Only signed firmwares can be done on this phone.
Score 1
While update firmware the modem firmware also upgraded so, downgrade is not possible on.
Score 1
Apple has already turned off servers that digitally signed iOS 10 to allow for installation. Without this signature it is impossible to install iOS 10. If you used tiny umbrella to save those already signed signatures, you would still be able to downgrade to iOS 9 because the way the iOS signing occurred differently.
Score 1
Voeg je antwoord toe
moha98med zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 13
Altijd: 6,442
