Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
483 Vragen Bekijk alle
Display Power Cable orientation
Mid 2011 iMac 27"
When installing an SSD drive, I put too much strain on the Display Power cable socket.
The pins appear undamaged, but I am not sure if the grooves in the socket and small lugs on the plug are still intact and therefore, I could possibly insert the plug either way.
To identify the correct orientation of the plug, I see that a small section of the brass connectors is visible through the plastic on only one side.
I see that these are on the outside (away from the circuit board) on the display end of the cable,
Is it the same on the logic board, i.e. insert the plug with these nearest to you, i.e. away from the logic board?
Any help greatly appreciated
Update (12/21/2017)
Thanks for interest in my problem.
As I reported, the cable does not lie flat to the plane of the rear of the display, but almost convinces me that my preference for visible brass on one side of plug should be outermost.
Here is my plug and I hope the tiny brass parts of the connectors show up.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
A1312 27" iMac 2011, LCD LED Display Screen Power Cable 593-1353 A
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
4 Antwoorden
Gekozen oplossing
That cable lays flat against the back of the display. So when you hold the display up to plug the cable in just don't twist it it and it will be in the proper orientation.
UPDATE
That appears to be the LED driver board cable:
iMac Intel 27" EMC 2429 LED Driver Board Replacement
Was dit antwoord nuttig?
Score 3
Commentaar:
Thank you for the suggestion and it almost convinces me but my cable does not lie in quite such a straight line as this. I will try to post picture to demonstrate
door
Yes, the visible slots should be facing outwards. If you look closely at the sides of the plastic plug-in, you will see a small ridge or nipple. These will be insert guides and allow you to insert plug one way. Use a magnifying glass to inspect and you will see one on each side.
Score 2
Commentaar:
Thanks Mike. I thought I could see the ridges on the plug, but I think I have reduced the size of these and their mating grooves on the socket by putting too much strain on that cable whilst unplugging other connectors.
It remains to be seen, if I have done irreparable damage to the socket, in which case I suppose a new logic board would be required. Thanks again.
door
As it turns out Apple uses the same connector in the MacBook Pro Unibody series. Here's a better image of the interface:
The contacts are facing you (outwards) and the detents the board clip snags are only on the outside facing side the wire bail is rotated over the connector to clip on its backside.
Commentaar:
Unless I am not understanding the photo correctly, this is not the same type of plug. I will try to post picture
door
Your right! this is the LVDS data connection.
door
The brass goes up when plugging in
Score -1
Commentaar:
I think this, like the comment from Dan previously, may be referring to the Screen Display cable and not the Display power cable. The tiny holes with brass showing through from the 6 pins appear on one side of the plug and as the plug goes into the socket vertically, they are either at the front (nearest to the display) or at the back (nearest to the logic board). My feeling is now that they are at the front.
door
Voeg je antwoord toe
David Storer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 30
Altijd: 537
