Weird touch screen/reboot issues after screen replacement
So, I’ve fixed many iPhone screens and I’ve never had this issue before
First, after the screen had been assembled onto the device, I boot it up by plugging the charger in as I always do.
The screen seemed to be working fine as far as touch functions are concerned. I allowed it to charge for awhile before giving it back to the customer
So, before I went to work, I turned it off. When I came home from work, I turned the phone back on to double check that everything was still functioning properly.
This is where the issues began, the touch did not work and it had a “phone is disabled for 5 mins” message on the home screen. I unplugged and re plugged the battery and flex cables to make sure I had good connections all around. Everything seemed to be fitting fine.
So, when I turned the phone back on.. viola! The touch is back working....turn it off...touch not working. Repeat the previous procedure of unplugging and replugging the battery, turn phone in, and touch is back working
It’s currently working but I’m scared to turn it off again. I’ve never had this issue. What do I do?
Is dit een goede vraag?
