Replacement transistor (304) on pins U11 & C37
I've replaced the left analogue stick potentiometer, but in doing so have damaged the transistor that's soldered nearby on pins U11 and C37. I tried a replacement transistor, but the controller inputs seem to be cutting out (pressing and holding a button results in the system believing it's a rapid tapping).
Does anyone know the correct spec part for replacing this transistor?
It’s on the back of the main board, next to the pins for the left stick potentiometer (circled in blue).
Is dit een goede vraag?
5 opmerkingen
Did you ever figure out what C37 is? I read below that U11 is a hall effect sensor, but what about C37? I was an idiot and accidentally lost it in the carpet.... So I'm afraid of what might happen if I don't replace it :(
door Grant Perdue
“304”
https://www.allegromicro.com/en/products...
https://www.allegromicro.com/-/media/fil...
door Dj Kc
c37 same as c33 on the other side, 1uf is the value
door Epic Tech
I've kinda just started doing this so need some help I done abit of repair work found out the trigger was broken also so put a new one on aswell but put it all together checked it all and all works fine but found out the trigger is not working a closer inspection via my microscope I saw that the component for c37 is not there which is a problem I've seen its the same as c33 but I don't no what c33 is is it a resistor or capacitor or none its really hard to buy another one when your trying to have a guess to what it is help would be much appreciated thankyou
door Callum Leedale
i have a similar issue, kinda, my hall sensor for the right trigger came off and the solder pads for the input and output have come off as well. is there any place on the the trace for this that i can solder it too instead?
door Jacob Rogers
