Ga door naar hoofdinhoud
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Vragen Bekijk alle
What do I need to remove data from hard drive in dead MBA 2013 13"
I have a MacBook Air 2013 model A1466 EMC 2632. The computer is dead after water spill. I want to retrieve data from hard drive and have removed hard drive. But the first kit I bought doesn't fit together properly.
I bought this and the opening is a bit too small for my hard drive.
KNACRO Adapter Card to M.2 NGFF x4 for 2013 2014 2015 apple MacBook Air A1465 A1466 / PRO RETINA A1398 A1502 A1425 SSD
Sold by: KNACRO
This item I was told to purchase seems useless but it is definitely the same size as the actual hard drive.
Will the ifit it adaptor word for this?
Is dit een goede vraag?
4 opmerkingen
This adapter allows you to fit an Apple Blade SSD in a PCIe slot of a Windows system. It won't help you get access to the files as you need a Mac to do that.
door
JFYI l have done it on windows booting a USB stick with Linux....and it will read any Mac drive..
door
You still have a problem here even if the OS is Linux and can read the SSD.
You can't access the files which only a Mac app created (stored). Yes, some files are readable like MS Word with MS Windows or OpenOffice.Org in Linux but, you couldn't savage much more. This is were a Mac system is a better direction and in most cases easier for someone to get to and likely want to stick with.
door
Thankyou for this advice Dan...I have retrieved music and photos from a failed Mac using this method...Apple is basically unix and so is Linux....but maybe later iOS developers are trying to close this loophole.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Sadly Apple uses a custom Blade SSD which does make getting data off a bit harder. Here is the unit I use: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Enclosure - For Apple Flash SSDs (June 2013-Current Mac Models)
It will allow you to connect your blade drive to a second Mac to off load your stuff.
If you look on eBay or Amazon you might find a used one as often people sell them after they've saved their bacon from similar events ;-!
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Drop it in this OWC enclosure and plug it into any Mac.
https://eshop.macsales.com/item/OWC/MAU3...
You can help recover your costs by reselling it on eBay.
Score 4
Easiest way I know is to use hired boot disk...just google hire some boot....download the ISO and USB maker...then run it as first boot on any pc...with the Mac drive on a USB adapter or dock....then select Linux....gparted on the dropdown menu...then drag and drop the files onto a pc that has enough storage space on its own hdd....trying to read a Mac on a pc directly just doesn't work but Linux can read it.
Update (12/18/2017)
That should read hirens...but you can also download a version of Linux and run it off a USB without installing it....then read the Mac drive and save whatever files you need...once saved burn it to disc.
Score -1
1 Opmerking:
You're assuming the system can be booted with a different OS "The computer is dead after water spill" So whats needed is a physical means to access the drive externally from a second system.
door
Voeg je antwoord toe
komarv zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,985
