Ga door naar hoofdinhoud
Repair guides and support for the Leap, a 5" smartphone running the BlackBerry 10 Operating System.
5 Vragen Bekijk alle
red light keeps blinking
my blackberry leap just red light blinking?
Is dit een goede vraag?
Score 1
1 Opmerking
my fone says bberror,doesnt wanna switch on
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If the light blinks twice fast then slow 3 times but never turns on, it means the device is soft bricked. This happens when the OS is corrupted or somehow the wrong version of the OS has been flashed on (Like I did). You will need to do a factory reset to bring it back to life.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
how do u do the factory reset
mine is bricked as u say but i dont know how to flash or whatsoever
door
when connected to pc it says no device
door
i try the factory reset is not working
door
im assuming the device itself does not boot up for this, because the red light blinks when you have notificationas as well.
If you plug your device in to a PC, and it is recognized, you likely have a screen failure.
If it is not being recognized, then i would start to think you have further issues. Red flashing LED indicates a general hardware failure, which could be most anything. (battery, camera, etc) most commonly however, it is a board level failure.
Voeg je antwoord toe
Anthony Enriquez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 3,526
