Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5140 Vragen Bekijk alle
Why is my lock button not working anymore?
Hi there,
I decided to renew the hardware of my iPhone 6 in order to extend its life and bought a new battery, lighting and jack connector, earpiece and loudspeaker from ifixit Europe.
Replacing components was pretty easy thank to the guides I found on the website and I did it all in one go.
The only exception was the removal of the old battery. I tried taking away the glue stripes as shown in the guide, but they broke and went under the battery, so I had to lever it out with some of the tools. I am afraid I may have damaged something because when I reassembled everything, the lock button didn't work anymore.
Now it may not depend on the way I removed the battery, maybe I just moved something without noticing(?).
Does anyone know what I can do to check what happened?
Any help is much appreciated.
Thanks
St3fan0
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You may follow this step:
Power off
Remove the front screen assembly
Remove the battery
Unplug the dock connector assembly
Remove the logic board
Fix the stuck power button
Replace the logic board
Replace the battery
Reconnect the display assembly
est your newly fixed iPhone 5 power button
Was dit antwoord nuttig?
Voeg je antwoord toe
st3fan0 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 3,073
