Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
iMac won't power up
A few days ago I tried to install an SSD along with the original HDD, using the tools and instructions from here:
Everything went smoothly but, sadly, when I closed back the computer, it would not power up at all. I opened it again to look for anything that might look off, but I did not found anything obviously wrong. Of course, I also tried disconnecting the new hardware and try to revert to its original configuration, but it would still not power up.
The symptoms are:
  • The diagnostic LED #1 does light up whenever the computer is plugged in.
  • No other diagnostic LED lights up at any time.
  • When I push the power button, I can hear a faint "pop" from the speakers, I think.
  • When I push the button to power the computer on, it does not turn on, but I do get 12 Volts between pins 1 and 11 of the logic board (Apple Technician Guide, p. 36, step 7). This voltage remains indefinitely until I hold the power button for a few seconds, as if to forcibly power it down.
  • As long as the computer is in this "on" state, the PSU makes very faint periodic chirp sounds. I do not know if this is normal because it could have always been making them during normal operation and I probably would not have heard them. Anyway, I did make a recording of these sounds: Chirp Noise
Any clues as to what may be wrong and how to fix it? Thanks!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I don't know a ton, but according to the Apple Technicians Guide:
LED 1 Indicates that trickle voltage from the power supply has been detected by logic board.
  • This LED will remain ON whenever the iMac is connected to a working AC power source.
  • The LED will remain ON even when the computer has been shut down or put to sleep.
  • The LED will remain OFF only if the AC power source is missing or disconnected, if the logic board is disconnected from the power supply, or if the power supply board is faulty.
So your getting power. But there is still a chance the PSU could be bad. Try unplugging everything from the motherboard and PSU that isn't needed (So pretty much just the hard drives) and then try to boot.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Hi, Cameron. First of all, thank you for taking the interest to reply. As you can see in my original question, I do have the Technicians Guide and I have followed its steps. It stands to reason that either the motherboard or the PSU is failing, but I cannot afford to buy one of each just to see which is the culprit, so I thought I'd ask anyway, in the off-chance that someone could recognize the specific symptoms and pinpoint the problem.
door
I see. It is confusing because your getting power, but that doesn't mean the PSU is bad. But depending on where you get the part, try a PSU and if it fixes it, keep it. if it doesn't, return it, get your money back and then get the motherboard. I'm not an expert on these, so I'm just trying to help as much as I can.
door
Thanks for the suggestion. I have indeed located a not-so-expensive used PSU and will try it this weekend.
door
I'm wondering if you might have pinched the SSD's power cable. The route it takes can put it at risk of a pinch. Loosen the logic board a bit and see if that changes anything. I would carefully pull a bit on the cables to be sure they are loose.
Adding a SSD as a second drive shouldn't have effected anything unless you damaged a connection. Did you have a hard time popping off any off the connectors?
Score 1
1 Opmerking:
No, the only hard time I had was getting the data SATA cable to fit the motherboard without taking the whole motherboard out. Other than that, I am not aware of having damaged anything. Anyway, I will be sure to double-check the power cable, as you suggest. Thanks!
door
Voeg je antwoord toe
Asuranceturix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 571
