Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Phone won't turn on
I have an iPhone 5s. It won't turn on it wi stay at the apple logo and then go blank and turn back on and go to a red screen with lines going through it. Even when it's on charge it does the same but as soon as I unplung it , it stays at a black screen Can anyone tell me what's wrong ?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There could be a couple of things here to look out for. Obvisouly, trying a new battery is the first thing to do. The 5S is an old device and the battery may be depleted. If a known-good battery doesn't solve the problem, then I would try to disconnect the FCAM/Sensor Flex as the proximity sensor can cause this type of issue. If disconnecting the flex works, then you can order a new one and replace it.
iPhone 5s/SE (1st Gen) Front Camera and Sensor Cable Afbeelding
Product
$9.99
Was dit antwoord nuttig?
Score 1
Hit the power button!
(Ha ha)
Likely you need a new battery.
Voeg je antwoord toe
danielle rose zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 64
