Ga door naar hoofdinhoud
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 Vragen Bekijk alle
My ipad doesn't turn on
Hi,
I tried to erase my ipad from the option in Find My iPhone Website,
After that my ipad doesn't turn on,
I tried to restart but still a smal circle apper at the center of a black screen **runing, like what happens when u wait a pge to be downloaded** and it doesn't open
What happened?
What should I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Plug it into your PC.
1) try a hard reset. (home button + power button for 15 seconds, or until the apple logo comes on.)
2a) Recovery mode. (home button + power button, until you get an image. continue holding these buttons until the screen goes black again, then release them. it should say "connect to itunes"
2b) Factory reset.
there are other things you can try replacing if the above doesnt work.
--battery
--Charge pory
If the above doesnt work, you are likely looking at a Motherboard failure.
Was dit antwoord nuttig?
Voeg je antwoord toe
Rawani A zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 52
