Ga door naar hoofdinhoud
Repair and support for the third generation of the Flip portable speaker by JBL.
My JBL Flip 4 won't power on
To be clear I have a JBL Flip 4, but the flip 4 wasn't listed in the categories...
When I plug it in, it shows that the battery is charged, all lights are white, and the last one blinks to show that it is charging that last little bit. But this is the only sign of life. I've tried holding the power button for 30 seconds (a recommended re-set technique), I've tried powering it while plugged in and while not plugged in. I plugged it into the wall, into my laptop- same thing every time. I tried a "fix" on this site that said to plug it in, and immediately remove the charge chord, and press the Bluetooth + button, and the Play button at the same time. But this is supposed to power down the speaker, my problem being that it never turns on.
my speaker is less than 6 mo old.
Any help would be great!!!
Is dit een goede vraag?
Score 2
5 opmerkingen
I have the same problem
door
I also have the same problem!
door
I also have the same problem.....my speaker is also 6 mos. old
door
Same problem
door
Same problem with my flip5. I had my first one stolen and now this one isn't even three months old and it will not boot up. I hope some of these kooky fixes work
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
You have tried the wrong methods, the actual method is push the connect button and the volume plus button simultaneously until it turns out when it is charging.
Was dit antwoord nuttig?
Score 7
6 opmerkingen:
Thank you so much!!!!
door
Thanks, helped with the first try.
door
Didn’t work for me :(
door
I did your actual method while plugged in, held the buttons until the lights went out....I still won't power up. Does it need to be recharged?
door
Thanks this worked fro me!!!
door
1 commentaar meer tonen
It didn’t work for me……Only the white and charging dots light up when I plug it in….then when I push the connect button an d volume up button, the other light left of the power button turns on,then almost immediately both go out.  I have to unplug from the wall, then plug in again, to repeat this process.  Will not power up.
1 Opmerking:
Mine does that exact same thing .did you ever figure it out . help plse
door
With my JBL Flip 4, I had no light or power turning on. It turned out to be the internal connection. to fix this you need to take it apart somewhat and just push the connection in a little. took about 10 mins. Mine turned on right away. this youtube video walks you through it. https://www.youtube.com/watch?v=_ygjoN3I...
Voeg je antwoord toe
rion zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 37
Altijd: 20,088
