Ga door naar hoofdinhoud
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
247 Vragen Bekijk alle
Why cant I hear a caller or dial tone but they can hear me
When making a call I am unable to hear a dial tone or the phone ringing or the person being called but they can hear me. When someone calls me, I Swype to answer the call but don't hear a connect tone or the caller. Texting functions seem to work fine. Audio works fine when watching a movie or listening to on line media.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Can you hear a caller OK when using the earphones with the microphone attachment on a call?
Can you hear the caller OK when using loudspeaker(or hands free) mode? You should be able to hear OK in this mode as given your description - "Audio works fine when watching a movie or listening to on line media", - the loudspeaker seems to be working.
If you can hear OK on a call when using the earphones and also when using the loudspeaker option then the problem is either a faulty (or loose) receiver in the phone or perhaps there is a problem with the earphone jack
Was dit antwoord nuttig?
Score 1
No when someone rings me they can’t hear a dialling tone it doesn’t ring on there end !!
Voeg je antwoord toe
Terry Dallman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 5,374
