Can bevel above hinge be replaced easily
i have Macbook pro with touch bar Model A1706
The bevel above the hinge (where it says Macbook Pro) has hairline cracks Think might be a issue using a laptop protective cover
Can it be repaired ??
Update (11/30/2017)
Thanks for reply
Ho much to repair ?Do you think a common problem?
Think damage caused by Macbook hardcase shell
see picture attached
looks as if when closing lid causes a pinch point because case clips on back by hinges
Do you think Apple would cover under warranty ?
Is dit een goede vraag?
