Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4554 Vragen Bekijk alle
Dropped in Toilet Water 35 mins ago
Guys i need help, im new to this but this community seems so smart about these types of things, i dropped my phone in the toilet and during flushing i dropped it in the toilet and picked it out immediately, i had no rice here so i nipped to the shop and put it in a bowl of rice approx 35 mins after the contact with water, is it saveable?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
Before I get into the actual fix for the phone, rice fixes nothing. It typically makes things worse because of the placebo effect where you THINK it helped, but it makes things worse by slowly killing the phone until it’s BER and needs to be outright replaced. How this rice myth hasn’t died yet is beyond me.
The main thing to do with water damaged phones is to unplug the battery and cut off power as soon as you can. The problem with this on the iPhone is late model 4's and newer use a P2 Pentalobe, which very few people have handy. Most electronics oriented driver kits now include it, but it's still not common.
The first thing you want to do is to remove the battery to preserve your chances of repairing your phone. You can refer to this guide to do it: How to Replace Your iPhone 6 Battery
Once you remove the battery, remove the motherboard from the phone. The link to do this can be found here: iPhone 6 Logic Board Replacement. Once the board is removed, follow this guide as a starting point to clean the board: Electronics Water Damage
If you have access to a ultrasonic cleaner and cleaning solution, this is the best way to clean the board. While it isn't worth going out and buying one as a single use item, it may not a bad investment. This will get under the IC’s on the board and improve the odds that the phone will last beyond a small amount of time since you cannot get to the corrosion under the chips with alcohol and a toothbrush. Harbor Freight sells a small one for $78.
The next thing to do is to replace the battery - do not clean this or attempt to reuse it. In most cases with water damaged phones these are compromised in some way. The damage is usually limited to runtime (and it's so bad you're forced to replace it anyway), but if the runtime is fine and the BMS is damaged it may not end well. If anything, do this for safety reasons.
While the board is out this is also a good time to clean the connectors for things like the TouchID sensor and camera modules and other damaged components. It’s better to replace these before you reassemble the phone so there are no unwanted gotcha problems. It's likely your speaker and headphone jack will be damaged, so I'd recommend ordering replacements when you order the battery. Keep these around just in case as well, as you may need them in the future because of the fact it has water damage.
iPhone 6 Battery afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 - 45 minutes
iPhone 6 Logic Board afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Was dit antwoord nuttig?
Score 3
Commentaar:
Here he is! .
door
My phone (a 6) has been sat in rice for about 48 hours is there any chance it’ll work it was in the water for about 10 seconds
door
Save the rice for cooking (although not that used rice)
Give this video here a shot:
How to get rid of water damage iPhone 6
Score 2
Commentaar:
Appreciate, shall have a browse now fella.
door
I beleive @nick is pretty good with these issues
door
@captainsnowball is there anyway i can private message him
door
I don't think so...
door
Maybe tomorrow @oldturkey03 or @mayer will be able to help.
Note to Mayer: sorry I've been calling you so often. just trying to send people to get help where my expertise end.
door
1 commentaar meer tonen
Aaron Cecil you should've skipped the rice. It does not work and does not protect your phone from corrosion. The very first thing you want to do is to not try to restart/sync the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides. You must remove all the EMI shields of the logic board. If you do not remove those you are not cleaning 3/4 of the board. Clean everything with +90% (no less than 90%) isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. Pay particular attention to the SMD components, check for charred missing or broken missing. You can then dry the board in an oven or equivalent at 220deg F (not higher;-) for a few hours. Best way to clean it would of course be through an ultrasonic cleaner. Consider professional help with that When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.
Score 2
Voeg je antwoord toe
Aaron Cecil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 20
Afgelopen 7 Dagen: 153
Afgelopen 30 Dagen: 784
Altijd: 13,857
