Ga door naar hoofdinhoud
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 Vragen Bekijk alle
Ipad restarts every 3 minutes after complete rebuild.
Hi everyone.
I had a customer who's son broke their ipad. From initial looks, it was the LCD, Digitiser and chassis which had broken.
First I established that if I can turn on the Ipad and check its functionality I would swap out the LCD and Digitiser to do so which worked well and I tested that everything was in working order. The customer advised me that he would like the chassis changed as he couldnt deal with the bent chassis anymore.
I completed a chassis change but the original battery didnt survive the swap over. I therfore purchased a new Ipad battery and before attempting sealing the Ipad thought ill make sure everything works.
My main problem I have now is that the Ipad starts up and after approximately 3 minutes it would restart.
Other indications:
1)when the Ipad is on, and on charge, I get a charge symbol but percentage does not go up.
2)When ipad is Off and on charge for a while and switched back on, Percentage does increase.
3) Continually restarts regardless of whatever I do.
I personally think its a battery fault for the restart that I may of not allowed it to charge properly first before switching on.
My main objective is to stop the restarting every 3 minutes.
Thoughts?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Probably a bad battery.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
My suspicion also.
When a new battery is installed and charger cable is inserted, the iPad starts up, Is it best practice to switch it off immediately and just leave it to charge?
door
I usually just charge up the iPad as normal.
door
I am going to acquire a new battery, Is there a pretest I can do before installing it with a voltmeter to ensure it's going to give me the full beans?
door
Well with a digital multimeter, you can really only test if the battery has sufficient charge or not. 3.7-4.2 voltage range.
door
Voeg je antwoord toe
Matt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,342
