Ga door naar hoofdinhoud
The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
Why is my idiot light on a 2007 Acura DMC saying "Battery not charging
I have a 2007 Acura DMX. Today (11/21/2017) I took the car out in a heavy rain. Eventually, I lost power. Pulled over side of the road, waited awhile and started car up again. Idiot light came on to say "Battery not charging" but I could run the car. However, power steering was totally gone and had great difficulty in turning the wheel in either direction. I thought everything had gotten soaked from the heavy rain. It is now 8 hours later. Car is parked in a warm garage in my house. Turned up car again. Again, idiot light came on, "Battery not charging". What should I do in this situation. Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@expofrosty double check your belts. Since you have no power steering and your "Battery not charging" could be a sign of a broken alternator belt. If the belt is okay you will have to consider to get your alternator checked (try places like Autozone or your dealer) with a worst case scenario of replacing your alternator. Check on here for that.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Bob FitzPatrick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 230
