Ga door naar hoofdinhoud
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Vragen Bekijk alle
Why is my phone showing the battery like it's charging then it's not
Why is my phone showing the battery like it's charging but not ALSO why is it that when I enter bootloader it freezes when I click one single choice PLZZ HELP
Is dit een goede vraag?
2 opmerkingen:
@pccheese can you give the PC software that gives the status on this phones battery?
door
@mayer I don't know of a PC solution but I have a nice app available on the play store.
https://play.google.com/store/apps/detai...
door
Voeg een opmerking toe
2 Antwoorden
It can depend on a couple things,
The charger you have may be incorrect. The charger should display the amps on it, and also inside the battery, make sure they match up.
Another thing is your battery may be fried, could be best to get another one, Try charging your phone while it's off too.
I used to be using the incorrect charger and I was using my phone plugged in and my battery was still discharging.
I'm not sure what you mean about bootloader, you may have to go more into depth...
Hope this helped :)
Was dit antwoord nuttig?
I think you need to replace the battery sounds like your phone has been around for a long time
Bucs Host
1 Opmerking:
Or the phone if possible @dave7
door
Voeg je antwoord toe
Kelvin Valladares zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 56
