2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
214 Vragen Bekijk alle
Changed screen and now have only white screen when turn on computer
I changed the display screen with new one, turned on and get a white screen? checked all connections, even plugged in broken screen and it still lit up on part of glass not cracked. any ideas?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
What happened with the previous screen to need a replacement ?
door
Daughter dropped off desk and cracked the screen, ultimately had to send to Apple and was fixed
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
The original screen had a small crack after falling off a desk and the bottom half of the screen was not working. Ordered a replacement screen and the replacement screen was faulty.
Was dit antwoord nuttig?
Het nuttigste antwoord
surely this is a software problem. Try starting up from an external USB device with a known good system on it. If it boots, run Disk Utilities from the external drive and see if that will do the trick.
Score 2
Maybe you have not connected all the wires. If it is not of this then you will need programming pairing which only Apple does, and because you replaced the screen yourself they may not do it because it is Apple .
Score -1
Commentaar:
Never heard of that before. There is no programming a screen.
door
I like to see some validation of this programming pairing. Could you give us a link?
door
Voeg je antwoord toe
herrky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 141
