Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
A business-class notebook with a 13.3" touchscreen display.
12 Vragen Bekijk alle
My laptop is plugged in,charging but actually its stuck at 0%?
My laptop is plugged in and showing its charging but actually its stuck at 0% and only working with power attached
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
STUDEER ZONDER OPLADER
Batterij-reparatiekits voor Mac
Koop reparatiekits
Koop reparatiekits
2 Antwoorden
Gekozen oplossing
Most likely you need a new battery. Average life is only around 3 years.
In answer to your comment:
Try running BatteryInfoView available from www.nirsoft.net - this should give you the status of your battery.
And yes, with care, batteries can often last a lot longer than 3 years, particularly if kept cool and minimising discharge/recharge cycles, but in normal regular use you can't really feel hard done by if a battery is fading after 3 years.
For everything there is to know about batteries, check out http://batteryuniversity.com/
Was dit antwoord nuttig?
Score 3
Commentaar:
Hmm. I've always wondered what average battery life is... thanks!
door
Is there a quality battery monitoring program for PCs like Coconut Batter for Macs?
Three years is half of what I am getting on a Mac.
door
You must test your power adapter in another laptop. If this cant help. Please reinstall Windows. If all this solution doesnt work you must change your battery.
Voeg je antwoord toe
waqas ahmad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 81
Altijd: 4,617
