Ga door naar hoofdinhoud
Modern rebirth of John Cooper's classic automobile, made by BMW.
13 Vragen Bekijk alle
heating issue mini cooper 2005
even, fan, thermostat are correctly operating and coolant liquid is fool, the temperature is high.
could you, comment about the common problems and the respectly solutions for this issue,
thanks a lot.
Juan José Blas
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi Juan, if the thermostat is operating normally then there could be air stuck in the system which is what's causing the overheating. I would have the system bled.
Was dit antwoord nuttig?
Score 1
Juan Blas make sure that your radiator is not obstructed by anything, that your fans come on appropriately. After that you'd possibly be looking at water pump issues.
Score 1
Voeg je antwoord toe
Juan Blas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 537
