What cpu that I can upgrade to.Or is it upgradable at all
I would like the cpu to be better then intel pentium dual cpu t2390. My device is a Sony VAIO PCG-7133L
Is dit een goede vraag?
Look for a Core 2 Duo from the T7xxx series.
Was dit antwoord nuttig?
are sure that i can replace the cpu
would a core duo t7800 work
would a i5 520m work too
While most laptops have integrated CPUs, the Vaio, in a lot of the models is replaceable and not integrated. Here's a video on replacing on a very close model, the VAIO PCG-71211v: https://www.youtube.com/watch?v=dXwJo896...
and here's another close model guide for doing it: Sony Vaio VGN-NW240F (PCG-7184L) Processor Replacement
So to tell, take a look at the CPU and see if it has a screw to loosen to take it out. If so then we can do some research as to what it might be able to accept.
would a core i5 520m work
You cannot go to the i5 you have to stay with a core 2. Next tell us what socket it has. Did you look at it?
@mayer according to the motherboard specs it should be a PPGA478 socket....I guess you have to see what GameKing will tell you.
Lets make exactly sure of what you have:
PCG-7133L is associated with the models listed below.
This occurs when multiple names and numbers are defined for the same or very similar models.
Check the model/product name or number listed on the sticker located on the back or bottom of your unit. One of them should match a model in the list, and that is the one you should select.
VGNNR460D
VGNNR490E
VGNNR498E
Sorry this series uses a soldered CPU on the logic board.
Your only option is to replace the complete logic board.
are you sure
@danj it is not!
The one I had years ago had a one way socket that you could press the chip in but couldn't remove it.
@danj good thing it is not about the one you had years ago......;-) If it was "soldered CPU on the logic board" how did you "press the chip in but couldn't remove it"
I didn't want to have to explain it. its functionally soldered. If its a ZIF in this model then I'll be the wiser.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 2,097
