4 pad smd components
Does anybody know what the 4 pad smd components near the MagSafe adapter plug on the logic board are? They look like two 0402 chip capacitors stuck together side by side.
Edit:
I can't check the board rev right now, however the attached image shows two of the components, the third got pushed off trying to remove the MagSafe cable. On the board they're between the MagSafe plug and the hole where the fan goes.
Is dit een goede vraag?
11 opmerkingen
tjleps how about you post an image of that component and it's overall location as it relates to the logicboard with your question? That would allow us to see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that
It will also make it easier if you can tell us which logicboard number you have. It should look something like this 820-xxxx
door oldturkey03
tjleps thank you. Post one more picture of the logic board and mark where this component is situated so we do not have to guess.
door oldturkey03
Oldturkey, thanks for your prompt replies, I'm not by the board right now I'll try to get that info tonight or tomorrow morning. If you look at the upper right corner, the two similar components are immediately to the left of the two pairs of capacitors on the far right edge of the picture
door tjleps
Yes I do recognize the components but to properly identify what they are and what their specifics are, I would need to see where they are located on the board. This is important since I do not want to guess. No rush, we'll be here. Just add the @oldturkey03 so I get notified when you leave another comment etc.
door oldturkey03
@oldturkey03 the board number is 820-3662-A I'll upload a few more images to the post as well.
Thanks again for your help!
door tjleps
6 commentaren meer tonen
